方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The rod-airfoil con痝uration is a benchmark test case for aeroacoustic assessments of vortex- structure interaction noise. Several industrial devices are arranged in such a way that down- stream bodies are embedded in the wake of upstream bodies, such as gas turbines, high lift devices, helicopters among others. Aeroacoustic predictions usually rely on time dependent 皁w 痚ld information obtained from CFD for the determination of the aeroacoustic sources. The present work proposes a novel approach for the aeroacoustic prediction of rod-airfoil noise based on time-resolved PIV experimental data. The aeroacoustic emission of a NACA0012 airfoil in the Karman wake of a rod is investigated by means of 2D TR-PIV in combination with beamforming and microphone measurements. First the time evolving velocity 痚ld around the airfoil is measured using high-speed PIV. The corresponding pressure 痚ld is then deduced by spatial integration of a Poisson-based algorithm for quasi-2D incompressible 皁ws. Pressure and velocity computed on speci痗 surfaces around the airfoil constitute the source terms of the implemented Curle's and Ffowcs Williams-Hawkings's aeroacoustic analogies. The calculated Sound Pressure Level (SPL) is compared with the measurements obtained by far 痚ld microphones. Velocity visualizations in the spanwise direction provide qualitative information about the phase coherence of the vortical impingement along the airfoil span. Parametric studies are performed to evaluate the e甧ct on the acoustic prediction of the position of the integration surface and the numerical discretization methods employed.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
