方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Particle image velocimetry (PIV) experiments have been carried out to study the correlation between the high- Reynolds number turbulent flow and wall heat transfer characteristics in a two-pass square channel with a smooth wall and a 90 rib-roughened wall. Detailed averaged velocity distributions and turbulent kinetic energy for both the main and the secondary flows are given for a representative Reynolds number (Re) of 30,000. The PIV measurement results were compared with the heat transfer experimental data of Ekkad and Han [International Journal of Heat Mass Transfer 40 (11) (1997) 2525–2537]. The result shows that the flow impingement is the primary factor for the two-pass square channel heat transfer enhancement rather than the flow turbulence level itself. The characteristics of the secondary flow,for example,vortex’s shape, strength,rotating-direction and positions, are closely correlated with the wall heat transfer enhancements for both smooth and ribbed wall two-pass square channels. The rib-induced flow turbulence increases the heat transfer mainly because of the enhanced local flow impingement near the rib.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
