方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Experimental velocity measurements of a low-speed jet, performed using time-resolved tomographic PIV, are used to study the dynamics of large-scale structures and their sound radiation. The experimental results show the roll-up of axisymmetric vortices that pair downstream, and subsequently lose their azimuthal coherence. Models of linear instability waves using both steady laminar and mean-field base flows flow are applied. While good agreement can be obtained for the vortex roll-up frequency in the near-nozzle region using the laminar base flow, non-linear effects must be included, via the mean field, in order to capture the downstream evolution of both the fundamental and subharmonic (vortex pairing). The velocity fluctuations for both frequencies have a wave-packet structure with some jitter in the form of modulations of the spatial extent and amplitude of the envelope. The sound radiation is modelled using a jittering wave-packet model, an shows agreement with the exponential directivity shape of Laufer and Yen (J. Fluid Mech. 134, 1983).
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
