方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The three-dimensional behavior of flow transition in circular and 6-chevron jets at Re?000 is investigated with experiments conducted on a free water jet by time-resolved tomographic particle image velocimetry. The emphasis is on the unsteady organization of coherent flow structures, which play a role in the generation of acoustic noise. Shedding and pairing of vortices are the most pronounced phenomena observed in the near field of the circular jet. The first and second pairing amplify the axial pulsatile motion in the jet column and lead to the growth of azimuthal waves culminating in the breakup of the vortex ring. Streamwise vortices of axial and radial vorticity are observed in the outer region and move inward and outward under the effect of the vortex rings. In the jet with chevrons, the axisymmetric ring-like coherence of the circular jet is not encountered. Instead, streamwise flow structures of azimuthal vorticity emanate from the chevron apices, and counter-rotating streamwise vortices of axial and radial vorticity develop from the chevron notches. The decay of streamwise vortices is accompanied by the formation of C-shaped structures. The three-dimensional analysis allows quantifying the vortex stretching and tilting activity, which, for the circular jet exit, is related to the azimuthal instabilities and the streamwise vortices connecting the vortex rings. In the chevron jet, stretching and tilting peak during the formation of C-structures. Following Powell抯 aeroacoustic analogy, the spatial distribution of the source term is mapped, evaluating the temporal derivative of the Lamb vector. The spatio-temporal evolution of such source term is visualized revealing that the events of highest activity are associated with the processes of vortex-ring pairing and vortex-ring disruption for the circular jet, and with the decay of streamwise instabilities and the formation of C-shaped structures for the chevron case.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
