方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Much progress has been made in the understanding of the phenomenon of drag reduction by dilute solutions of polymers since its discovery in 1948. While the use of advanced techniques in experiments and computational simulations have dramatically advanced our understanding of the phenomenon, a complete and conclusive explanation of the physics associated with the phenomenon is still lacking. In particular, drag reduction in boundary layers with injection has not been studied extensively to understand the processes and physics that govern the spread and mixing of the injected polymer in the flow. To overcome this limitation, in the present work, drag reduction due to polymer injection in a turbulent boundary layer is studied using simultaneous Particle Imaging Velocimetry (PIV) and Planar Laser Induced Fluorescence (PLIF). PIV is used to measure the velocity of the flow in the boundary layer and to calculate higher order velocity statistics. PLIF is used to study the distribution and spread of the injected polymer in the boundary layer by tracking a fluorescent dye mixed in with it. The polymer of choice, polyethylene oxide, is injected as a dilute solution into a fully turbulent Newtonian boundary layer and measurements of velocity and concentration are made at different downstream locations on the flat plate to study the effect of the polymer on the flow and the evolution of drag reduction. The data from the two measurement techniques are combined to calculate turbulent fluxes and to estimate the turbulent Schmidt number in polymer drag reduced flows.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
