方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
A new compact micro-lens optical system has been developed to produce a 7 x 7 multiline optical grid for Hydroxyl Tagging Velocimetry (HTV). These lines provide additional spatial information and aid the software tracking of the flowfield by increasing its resolution. Single-photon photodissociation of groundstate H2O by a ~193-nm ArF excimer laser “writes” a 7 x 7 beam molecular grid with very long gridlines of superequilibrium OH and H photoproducts in either room air flowfields or in H2-Air flames due to the presence of H2O vapor. The displaced OH tag lines’ positions are revealed through fluorescence by A2Σ+ (v′= 0) ← X2Πi (v″ = 0) OH excitation using a ~308 nm pulsed frequency-doubled dye laser. A time-of-flight software (DaVis 6.0 Stereo PIV/PTV, LaVision, GmbH) determines the instantaneous velocity field. HTV tag lifetime comparisons between experimental results and theoretical predictions are discussed.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
