方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Measurements of the local flow and mixture condition near the spark plug of internal combustion engines are important to characterize their influence on ignition and combustion performance. This is especially true for direct-injection engines where limited time is available for mixture formation and optimum stratification of the fuel/air mixture to achieve best performance. Transient processes need to be visualized in an optically challenging environment. The application of digital Particle Image Velocimetry (PIV) for flow field measurements along with crank angle-resolved planar laser induced fluorescence (PLIF) and chemiluminescence imaging is discussed in the context of investigations of a highly stratified sprayguided direct-injection engine. Flow fields were captured in a firing optical single-cylinder engine to study the interaction of the fast spray and the underlying in-cylinder tumble flow. The impingement of the fuel spray on the spark plug electrodes and subsequent dispersion of the fuel cloud was filmed at a rate of 12kHz with a new PLIF technique using a diode-pumped Nd:YAG laser. Subsequent flame development and combustion progress could be followed via high-speed imaging of OH* chemiluminescence. This approach was also combined with double-pulse PLIF imaging of fuel distributions.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
