方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Lifting surfaces are used both for propulsion and control of sea vessels and must meet performance criteria such as lift, drag, and (in some military applications)hydroacoustic noise limits. Design tools suitable to predict such criteria must handle complex flow phenomena and manage the wide range of flow scales inherent in marine applications (Reynolds numbers ~108). To date, the development of such tools has been limited by the lack of controlled experimental data in this high Reynolds numbers range. Lifting surface flow is the focus of current high Reynolds number experiments involving a two-dimensional hydrofoil in the world’s largest water tunnel, the US Navy’s William B. Morgan Large Cavitation Channel (LCC). The goal of these experiments is to provide a unique high Reynolds number experimental dataset at chord-based Reynolds numbers (Re) approaching those of full-scale propulsors (~108). This data will be used for validation of scaling laws and computational models, with particular emphasis given to the unsteady, separated, turbulent flow at the trailing edge. In addition, these experiments will provide fundamental insight into the fluid mechanics of trailing-edge noise generation in marine propulsion systems. This paper describes the experimental equipment and methods employed in the test program. Described herein is the use of the LCC’s Laser Doppler Velocimetry (LDV) capability to acquire flow velocity mean and turbulence quantities, as well as estimates of boundary layer transition. Also presented is a Particle Imaging Velocimetry (PIV) system developed for these experiments and employing seed injection upstream of the channel’s flow straightener. Finally, a description is given of instrumentation mounted in the foil for measurement of vibration and surface static and dynamic pressures.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
