方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Stability of the Si-H bonds on the hydrogen-terminated Si(111) surface has been investigated by sum frequency generation (SFG) spectroscopy in air at room temperature. The SFG observation showed that the Si(111) surface is terminated by a monolayer of monohydride (Si-H) after etching in a concertrated ammonium fluoride (NH4F) solution. The number of Si-H bonds decreased with laser irradiation time and the abstraction rate of hydrogen atoms on Si increased with the increase of input energy of "visible" light. The Si-H bond under irradiation at 1064nm light was more stable than that at 532nm light with a given intensity. A small amount of water in air severely lowered the stability of Si-H bond because of a photoelectrochemical recation under laser irradiation.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
