方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Vortex generator jets (VGJs) have proven to be effective in minimizing the separation losses on low-pressure turbine blades at low Reynolds numbers. Experimental data collected using phase-locked particle image velocimetry and substantiated with a hot-film anemometer were used to answer fundamental questions about the influence of VGJs on a separated boundary layer. The data were collected on the suction surface of the Pack B blade profile, which has a non-reattaching separation bubble beginning at 68% axial chord. Two VGJ pulse histories were created with different frequencies, jet durations,and duty cycles. The mechanisms responsible for boundary layer separation control were shown to be a combination of boundary layer transition and streamwise vortical structures. Jet duration and relaxation time were important VGJ characteristics in determining the extent of control. The unsteady environment characterisitic of the low-pressure turbine section in a gas turbine engine effectively reduces the time-averaged separation zone by as much as 35%. Upstream blade rows create unsteady flow disturbances (wakes) that transition the flow. This transitioned flow propagates downstream, re-attaching the separation bubbles on the subsequent blade row. Phase-locked PIV and hot-film measurements were used to document the characteristics of this separation zone when subjected to synchronized unsteady wakes and VGJs. The phase difference between VGJ actuation and the wake passing, blowing ratio, and VGJ duration were optimized to achieve the greatest timeaveraged control of the separation zone. The experimental data were used to identify the important characteristics of the wake/jet interaction. Phase-locked PIV measurements were taken to isolate the wake event.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
