方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Two novel techniques based on Laser-Induced Fluorescence (LIF) were applied to measure gas-phase temperature distributions in boundary layers close to wall surfaces. Single line toluene-LIF thermometry was used to image temperature in a nitrogen gas flow above a heated wall. The nitrogen gas flow was doped with evaporated toluene. When excited at 266 nm, the toluene LIF-signal shows an exponential dependence on temperature. This behavior was used to calculate absolute temperatures from LIF images after calibration at known conditions. The second technique, multi-line NO-LIF thermometry was applied to image temperature in the quenching boundary layer close to a metal wall located on a flat flame burner. A small amount of nitric oxide was mixed into the air/methane mixture. NO molecules were excited in the A-X (0,0)-band at 225 nm. NO-LIF excitation spectra were acquired by tuning the excimer laser wavelength and recording the NO LIF-signal with an ICCD camera. Absolute temperatures were calculated for every pixel by fitting simulated excitation spectra to the experimental data. Temperature distributions close to the wall surface were measured at two different flow-rate conditions. A high nominal spatial resolution of 0.016 mm/pixel in direction perpendicular to the wall was reached. Wall surface temperatures were recorded simultaneously by embedded thermocouples and compared with gas-phase temperature near the wall surface.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
