方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Temperature measurements using planar laser-induced fluorescence (PLIF)are most often associated with experimental challenges. In addition, no PLIF technique is generally applicable in all kinds of environment. Especially under sooting conditions problems are prone to arise, which limits the use of these techniques. In this paper the two-line atomic fluorescence (TLAF) technique was investigated in sooting environments. Indium atoms were used as thermometry species and seeded into the combustion region. Data from two-dimensional measurements are often difficult to analyse, because of problems with treating noise. A statistical analysis method for correction of laser fluctuations was developed to increase the precision of the temperature calculations. The results show that TLAF holds promise for temperature measurements in rich combustion, such as diesel engines, where other techniques have proven to fail. Drawbacks with the TLAF technique are that the probe volume is biased towards the post-flame zone and that seeding is required. The statistical analysis improved the precision considerably and is suitable for evaluation of other two-dimensional thermometry techniques. This paper also presents a critical review and comparison with alternatives, such as OH and NO thermometry.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
