方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Turbulent dispersed two-phase flows are abundant in both industry and nature. The ability to predict the behaviour of this type of flow - either using numerical or theoretical models - will be benificial to a wide range of disciplines. However, a lack of consistent experimental data currently makes validation of both numerical and theoretical results difficult. The main aim of this thesis is to generate experimental data that could fill this void. In order to do so, a facility is built to generate isotropic, homogeneous turbulence. This is done using a grid in a vertical water channel. This new facility is validated and documented for the particle-free case using Laser Doppler Anemometry (LDA) and Particle Image Velocimetry (PIV). The results of both measurement techniques are in good quantitative agreement, and the flow is a close approximation of decaying homogeneous, isotropic turbulence.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
