方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
This is an experimental study to evaluate the development of the boundary layer thickness, δ, and momentum thickness, θ, along long thin flexible cylinders (L/a=1.5*105 and 3.0*105 where δ/a>>1, a=radius). The experiments use conventional test methods in conjunction with Stereo Particle Image Velocimetry (SPIV) measurement techniques to evaluate the flow in the boundary region of a small diameter flexible cylinder towed in the high speed towing basin at the Naval Surface Warfare Center Carderock Division (NSWCCD). The flexible cylinders are approximately neutrally buoyant and have an initial length of 152 m and radii of 0.45 mm and 1.25 mm. The first objective for this experiment is to evaluate the streamwise development of wall shear stress (τw) and momentum thickness (θ) in axisymmetric turbulent boundary layers using drag measurements at 3.1, 5.2, 9.3 and 14.4 m/s for comparison to existing data. The second and primary objective for this experiment is to determine the streamwise development of the axisymmetric boundary layer flow and to evaluate relevant boundary layer parameters at 3.8, 7.7, 12.9 and 15.4 m/sec using SPIV images acquired over the entire length of the cylinders. Drag measurements reveal that the wall shear stress is large and that the momentum thickness grows slowly when compared to flat plate boundary layers. The velocity field data shows that the boundary flow remains turbulent over the entire length of the flexible cylinder and that the turbulent profile is different from that of flat plate boundary layers.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
