方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Active control of a lifted flame is investigated using a coaxial nozzle with magnetic flap actuators arranged on the inner periphery of the annular nozzle. Near-field vortical structures of the methane/air coaxial jet are manipulated by introducing disturbances directly to the initial shear layer. Through the manipulation, we can improve flame stability and flexibly control the liftoff height. It is found that the large-scale vortical structures play a dominant role in the flame stabilization, and its spatio-temporal evolution is examined with the aid of PIV and LIF to elucidate the control mechanism. By introducing flap motion driven with a saw-wave signal, we can force the outer shear layer to roll up into strong vortices in synchronization with the flaps. When the flapping Strouhal number is unity, the lifted flame is anchored at x/Do ~ 1.5. The strong vortices induced by the flaps produce a blob of flammable mixture, which has velocity smaller than the flame speed. The possible stabilization mechanism is that the time period of the premixture supply is balanced with the consumption time of the premixture at the flame base. On the other hand, when the jet is manipulated by a square-wave signal, the lifted flame is located stably at x/Do ~ 4, which is downstream of the inner potential core. It is found that vortical structures in the shear layers break into turbulence close to the nozzle exit. The possible mechanism of the flame stabilization is that the flame propagating upstream is undisturbed due to the absence of intermittent passage of large-scale vortices.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
