一套应用于拖曳水池中的水下立体粒子成像测速(PIV)系统的调试运行
2008/06/16   下载量: 50
方案下载
应用领域 交通
检测样本 船舶
检测项目
参考标准 暂无
In January 2004, Memorial University purchased a stereoscopic Particle Image Velocimetry (PIV) system for making flow measurements. Although the system was potentially very versatile, its primary application was envisioned to be in a towing tank. The system was supplied as a complete package of hardware and software for calibration, data collection and analysis. The intention of the PIV system designers was to collect as many data frames as possible for a fixed measurement plane location, relative to the model. This required the PIV system to be fixed on the towing carriage, moving with the model being studied. It was found during some preliminary experiments that an active seeding delivery system was necessary to ensure sufficiently high seeding particle concentration, especially when measuring flow velocities around a model hull with a large yaw angle. This paper describes the development of a seeding technique for a PIV system that can be used in a towing tank. The paper also includes an estimate of the uncertainty of the measurement system, including the analysis of the flow behind the device used to deliver seed particles into the flow.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 水平环形两相流的局域液体速度测量
文献贡献者
相关方案
当前位置: 欧兰科技 方案 一套应用于拖曳水池中的水下立体粒子成像测速(PIV)系统的调试运行
