方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Along with the rapid growth of research of microfluidics, monitoring and understanding micro flow behavior is a challenge for researchers. Particle Image Velocimetry (PIV), a powerful tool that makes flow visible, was extended to microscale by Santiago et al. 1998. In this paper, we presented the micro Particle Image Velocimetry (μPIV) system at Nanyang Technological University (NTU), its calibration and characterizations of microfluidic devices using μPIV. Since the fully developed microchannel flow has been well investigated, it is suitable to calibrate the measurements of μPIV. In our experiment, an in-channel microdispenser fabricated on printed circuit board is used to form a microchannel. A syringe pump forces water that contains fluorescent particles. The flow field is obtained by μPIV. At the same time, a three-dimensional model with ANSYS/FLOTRAN was used. The comparison between the two results demonstrates that our μPIV system works well. Furthermore we use this system to characterize a Tesla valve - a non-moving part valve. The valve consists of a fluid channel structure that has rectification property, which favors forward flow while hampers reverse flow. The velocity fields are also validated by ANSYS/FLOTRAN.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
