方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Fluorescent tracer particles have found a number of uses in PIV. A light sheet produces flare when it impinges upon an object within the field of view, preventing particle images from being obtained and hence preventing velocity measurements in that locality. An example is shown in figure 1 where 532nm light is used for excitation and imaging. Whilst in some situations flare may be minimized by careful experiment setup, in some applications flare is difficult to avoid and prevents information from being obtained, e.g. in boundary layer measurements. A further application has been explored where fluorescent tracers are used to optically label one phase or constituent of a flow and thereby enable simultaneous multi-constituent PIV [1-3]. The general application of fluorescent tracers to gas phase flow seeding requires sufficient fluorescence emission from micron sized tracers when imaged over 10’s of mm field of view. For multi-constituent and multi-phase flows sufficient chromatic separation is also required between the illumination and the fluorescence and between the fluorescence and any wavelengths used for Mie scattering.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
