方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
We have studied the flow induced by a macroscopic spherical particle settling in a Laponite suspension that exhibits a yield stress, thixotropy, and shear thinning. We show that the fluid thixotropy or aging induces an increase with time of both the apparent yield stress and shear-thinning properties but also a breaking of the flow fore-aft symmetry predicted in Hershel-Bulkley fluids yield-stress, shear-thinning fluids with no thixotropy. We have also varied the stress exerted by the particles on the fluid by using particles of different densities. Although the stresses exerted by the particles are of the same order of magnitude, the velocity field presents utterly different features: whereas the flow around the lighter particle shows a confinement similar to the one observed in shear-thinning fluids, the wake of the heavier particle is characterized by an upward motion of the fluid “negative wake”, whatever the fluid’s age. We compare the features of this negative wake to the one observed in viscoelastic shear-thinning fluids polymeric or micelle solutions. Although the flows around the two particles strongly differ, their settling behaviors display no apparent difference which constitutes an intriguing result and evidences the complexity of the dependence of the drag factor on flow field.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
