用成像光纤簇进行全场光学断层扫描(OCT)测量
2016/10/24   下载量: 6
方案下载
应用领域 医疗/卫生
检测样本 其他
检测项目
参考标准 暂无
An imaging fibre bundle is demonstrated for spatially-multiplexed probe beam delivery in OCT, with the aim of eliminating the mechanical scanning currently required at the probe tip in endoscopic systems. Each fibre in the bundle addresses a Fizeau interferometer formed between the bundle end and the sample, allowing acquisition of information across a plane with a single measurement. Depth scanning components are now contained within a processing interferometer external to the completely passive endoscope probe. The technique has been evaluated in our laboratory for non-biological samples. Images acquired using the bundle-based system are presented. The potential of the system is assessed, with reference to SNR performance and acquisition speed.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 多孔介质双尺度瞬态流动行为的显微PIV研究
文献贡献者
相关方案
当前位置: 欧兰科技 方案 用成像光纤簇进行全场光学断层扫描(OCT)测量
