便携式发电机的催化微反应器
2016/11/16   下载量: 10
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
The test rig employed in this study consisted of a high-pressure cylindrical steel vessel with a length of 1.8 m and an internal diameter of 0.28 m. Visual inspection and accessibility of the reactor assembly was achieved via a 50 mm diameter quartz window at the rear flange of the vessel and two 350 mm long and 50 mm high quartz windows at the vessel sides. The test setup (Fig. 2.1) consisted of a channelflow catalytic reactor, which was mounted inside the high-pressure cylindrical vessel. The reactor comprised two horizontal Si[SiC] plates with a length (x) of 300 mm, width (z) of 104 mm and thickness of 9 mm; the plates were positioned 7 mm apart (y). The other two sides of the reactor were formed by two 3-mm-thick vertical quartz windows.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 3维失速团对层流NACA64 -418翼型压力分布的影响
文献贡献者
相关方案
当前位置: 欧兰科技 方案 便携式发电机的催化微反应器
