方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司最短帧间时间间隔可达115纳秒的跨帧相机,可以测量的速度上线可达十几公里/秒。本文的测试速度就达到了5倍音速。
An experimental investigation of sonic air, CO2 and Helium transverse jets in
Mach 5 cross flow was carried out over a flat plate. The jet to freestream momentum flux
ratio, J, was kept the same for all gases. The unsteady flow topology was examined using
high speed schlieren visualisation and PIV. Schlieren visualisation provided information
regarding oscillating jet shear layer structures and bow shock, Mach disc and barrel shocks.
Two-component PIV measurements at the centreline, provided information regarding jet
penetration trajectories. Barrel shocks and Mach disc forming the jet boundary were
visualised/quantified also jet penetration boundaries were determined. Even though J is
kept the same for all gases, the penetration patterns were found to be remarkably different
both at the nearfield and the farfield. Air and CO2 jet resulted similar nearfield and farfield
penetration pattern whereas Helium jet spread minimal in the nearfield.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
