方案下载应用领域 | 航空航天 |
检测样本 | 航空 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的时间分辨PIV系统测量了固体火箭发动机在风洞中的热气流喷射过程,并研究了喷射火焰热的内核与环绕热核的外部气体流动之间的相互作用。
A wind tunnel model containing a solid rocket motor
was tested at Mach 2 to assess the feasibility of
investigating the interaction between a hot plume and a
high-speed outer stream. In addition to Schlieren
visualisation, the feasibility of applying PIV was
explored. Recorded particle images revealed that the hot
plume scatters and reflects laser light, leading to a
strong deterioration of the illumination conditions in
regions within and near the plume. Suitable processing
of the particle images could partly compensate for this
and reliable velocity measurements could be obtained in
directly illuminated regions. In regions near the base
and below the plume, velocity measurements could still
be obtained but were considered to be of lower quality.
No reliable velocity measurements could be obtained
within the plume itself.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
