方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用英国Litron公司的30毫焦双脉冲PIV激光器,LaVision Imager Pro X PIV相机。在LaVision的硬件控制和数据采集软件平台DaVis集成控制下。对水中藤壶幼虫的游动附着过程进行了观测研究。
Water flow affects settlement of marine larvae on several scales. At the smallest scale local
flow regime may control the probability of adhesion to the substrate. Our aim was to mechanistically
understand the transition from suspended to attached larvae in turbulent flow.
Recently it was proposed that opportunities for larval settlement in turbulent boundary layers
depend on time windows with suitable instantaneous flow properties. In flume flow we
characterized the proportion of suitable time windows in a series of flow velocities with
focus on the near-bed flow. The change in the proportion of potential settling windows with
increasing free-stream velocities was compared to the proportion of temporary attachment
of barnacle cypris larvae at different flow velocities. We found large instantaneous flow variations
in the near-bed flow where cyprid attachment took place. The probability of temporary
attachment in cyprids declined with local flow speed and this response was compatible with
a settling window lasting at least 0.1 s with a maximum local flow speed of 1.9–2.4 cm s-1.
Cyprids swam against the near-bed flow (negative rheotaxis) and the swimming speed (1.8
cm s-1) was close to the critical speed that permitted temporary attachment. We conclude
that temporary attachment in barnacle cyprids requires upstream swimming to maintain a
fixed position relative to the substrate for at least 0.1 s. This behaviour may explain the ability
of barnacles to recruit to high-flow environments and give cyprids flexibility in the pre-settlement
choice of substrates based on flow regime.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
