方案下载应用领域 | 能源/新能源 |
检测样本 | 天然气/燃气 |
检测项目 | |
参考标准 | 暂无 |
用LaVision公司高灵敏度科学级CCD相机Imager Intense 测量多种模型燃料如n-dodecane, cyclohexane, isooctane, toluene, n-propylbenzene 和 jet-fuel (Jet A-1)等的层流燃烧速度。
Laminar burning velocities were measured for the neat fuel components n-dodecane, cyclohexane, isooctane, toluene and n-propylbenzene and for jet-fuel (Jet A-1). The measurements were performed using the cone-angle method and at a preheat temperature of 473 K and pressures of 0.1 MPa, 0.3 MPa and 0.6 MPa. It is shown that nearly all fuels have a similar pressure dependence and that the burning velocity of Jet A-1 is in between the burning velocity of the neat components. Also structural differences among n- and iso-alkanes are explained. In addition, a comparison to experimental data from literature is presented.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
