方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
LaVision公司的首席执行官Bernhard Wieneke是PIV领域的著名学者。在PIV不确定度的定量分析领域发表过多篇高水平,开拓性的文章。这是其中一篇。
This paper discusses the propagation of the instantaneous uncertainty of PIV measurements
to statistical and instantaneous quantities of interest derived from the velocity field. The
expression of the uncertainty of vorticity, velocity divergence, mean value and Reynolds
stresses is derived. It is shown that the uncertainty of vorticity and velocity divergence requires
the knowledge of the spatial correlation between the error of the x and y particle image
displacement, which depends upon the measurement spatial resolution. The uncertainty of
statistical quantities is often dominated by the random uncertainty due to the finite sample
size and decreases with the square root of the effective number of independent samples.
Monte Carlo simulations are conducted to assess the accuracy of the uncertainty propagation
formulae. Furthermore, three experimental assessments are carried out. In the first experiment,
a turntable is used to simulate a rigid rotation flow field. The estimated uncertainty of the
vorticity is compared with the actual vorticity error root-mean-square, with differences
between the two quantities within 5–10% for different interrogation window sizes and
overlap factors. A turbulent jet flow is investigated in the second experimental assessment.
The reference velocity, which is used to compute the reference value of the instantaneous
flow properties of interest, is obtained with an auxiliary PIV system, which features a
higher dynamic range than the measurement system. Finally, the uncertainty quantification
of statistical quantities is assessed via PIV measurements in a cavity flow. The comparison
between estimated uncertainty and actual error demonstrates the accuracy of the proposed
uncertainty propagation methodology.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
