方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
激光器采用Quantronix 双腔高重复率激光器。单脉冲能量25 mJ @ 1 kHz。系统配备6台Photron CMOS 相机。满帧分辨率1024 x 1024像素。
The momentum exchange mechanisms in a turbulent boundary layer (TBL) flow are of manifold
temporal and spatial scales and governed by the organization of self-sustaining coherent flow structures
driven by entrained high momentum fluid. Generic flow structures such as hairpin-like vortices and spanwise
alternating wall bounded low- and high-speed streaks have been observed and extensively analyzed with
both experimental and numerical methods, e.g. by means of PIV (Christensen & Adrian 2001, Kähler 2004,
Stanislas et al. 2008) or DNS (Spalart 1988, Robinson 1991, Kang et al. 2007). In many studies the role of
these structures for the wall normal and spanwise fluid exchange has been highlighted mostly within an
Eulerian reference frame. But for a full understanding of the momentum exchange in turbulent wall flows a
step towards a spatially resolved Lagrangian frame of reference would be advantageous.
The data achieved from the present application of time-resolved tomographic PIV to a flat plate turbulent
boundary layer flow in a water tunnel at Reθ ~ 2460 enables for the first time a topological investigation of
the flow structures and related particle motions within a temporally and spatially highly resolved Lagrangian
and Eulerian reference frame.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
