方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用ImagerProX4M相机。长工作距离显微镜。测量一个粗糙的砂轮圆盘在液体池中旋转时所产生的流场。
The prediction of the mean flow and turbulence structure of a boundary layer on surfaces with different type and
shape of roughness is still one of the major questions in fluid mechanics. The specific character of wall roughness in
terms of shape, size and distribution strongly varies from case to case and an equivalent roughness concept was
introduced in order to enable engineers to design systems with rough walls. The current paper shows a method to
obtain the roughness function of different surface roughness by using a small-scale rig with rotating disks and a
long-distance microscopic PIV in order to obtain submicron resolution inside the boundary layer developed on the
disks when they rotate. This rig was designed and constructed for the optical measurements and consists of an
electric motor which drives the disks that are rotating in the middle of a 20-liter water tank. The measurements were
performed on surfaces with different degree of roughness. These are a smooth reference, three antifouling coatings
used in marine applications, two different sand roughness and one case of periodic roughness. All measurements
were performed at two different Reynolds numbers (5.7×105 and 1.15×106), corresponding to disk rotational speeds
of 300 and 600 rpm. Field mean velocity profiles were calculated by averaging vertical bins with 1-pixel (px) width.
Every point of a mean velocity profile was based on near 200 instant velocity values obtained from 2000 PIV image
pairs by using particle tracking approach. The results of a wall shear stress study of the smooth disk case were used
together with torque measurements and the micro-PIV measurements for the different rough surfaces to come up
with their dimensionless velocity profiles. The results show that as expected, the velocity profiles are shifted
downwards due to the roughness presence. Finally, the skin friction coefficients of the different cases are compared
with previous studies and the roughness function is determined for the different surfaces. The roughness function is
very useful in some industries such as in the naval architecture field, where the drag can be better estimated and the
adverse effect can be better counteracted.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
