方案下载应用领域 | 生物相关产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的DaVis8.1.3软件的DVC模块,计算了格林-拉格朗日张量的6个独立分量,亚体积元为20x20x20体像素,75%重叠,所得结果的应变精度为20个微应变。
An annular sponge, saturated with 1.25% glutaraldehyde, was applied to the
external surface of the peripapillary sclera for 5 minutes to stiffen the sclera. Tissue
deformation was quantified in two groups of porcine eyes, using digital image correlation
(DIC) or computed tomography imaging and digital volume correlation (DVC). In group A (n
¼ 14), eyes were subjected to inflation testing before and after scleral stiffening. Digital image
correlation was used to measure scleral deformation and quantify the magnitude of scleral
stiffening. In group B (n ¼ 5), the optic nerve head region was imaged using synchrotron
radiation phase-contrast microcomputed tomography (PC lCT) at an isotropic spatial
resolution of 3.2 lm. Digital volume correlation was used to compute the full-field threedimensional
deformation within the LC and evaluate the effects of peripapillary scleral crosslinking
on LC biomechanics.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
