方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用两台LaVision公司的HighSpeedStar6 型高速相机,记录仿真蜂鸟扑翼机的振翅动作过程。
The stroke-cam flapping mechanism presented in this paper closely
mimics the wing motion of a hovering Rufous hummingbird. It is the
only lightweight hummingbird-sized flapping mechanism which
generates a harmonic wing stroke with both a high flapping
frequency and a large stroke amplitude. Experiments on a
lightweight prototype of this stroke-cam mechanism on a 50 mmlong
wing demonstrate that a harmonic stroke motion is generated
with a peak-to-peak stroke amplitude of 175° at a flapping frequency
of 40 Hz. It generated a mass lifting capability of 5.1 g, which is largely
sufficient to lift the prototype’s mass of 3.39 g and larger than the
mass-lifting capability of a Rufous hummingbird. The motor mass of a
hummingbird-like robot which drives the stroke-cam mechanism is
considerably larger (about five times) than the muscle mass of a
hummingbird with comparable load-lifting capability. This paper
presents a flapping wing nano aerial vehicle which is designed to
possess the same lift- and thrust-generating principles of the Rufous
hummingbird. The application is indoor flight. We give an overview of
the wing kinematics and some specifications which should be met to
develop an artificial wing, and also describe the applications of these
in the mechanism which has been developed in this work.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
