方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
层析-PIV,Tomo-PIV是德国LaVision公司独有的能够测量获得高分辨率全体积3分量速度矢量场的系统。本篇介绍了先进的运动追踪增强粒子重构算法MTE-MART的原理和应用。采用这种算法,在相同的硬件配置下,可以处理更高浓度的粒子场,得到空间分辨率更高的速度矢量场。
The motion-tracking-enhanced MART (MTEMART;
Novara et al. in Meas Sci Technol 21:035401,
2010) has demonstrated the potential to increase the accuracy
of tomographic PIV by the combined use of a short
sequence of non-simultaneous recordings. A clear bottleneck
of the MTE-MART technique has been its computational
cost. For large datasets comprising time-resolved
sequences, MTE-MART becomes unaffordable and has
been barely applied even for the analysis of densely seeded
tomographic PIV datasets. A novel implementation is
proposed for tomographic PIV image sequences, which
strongly reduces the computational burden of MTE-MART,
possibly below that of regular MART. The method is a
sequential algorithm that produces a time-marching estimation
of the object intensity field based on an enhanced
guess, which is built upon the object reconstructed at the
previous time instant. As the method becomes effective
after a number of snapshots (typically 5–10), the sequential
MTE-MART (SMTE) is most suited for time-resolved
sequences. The computational cost reduction due to SMTE
simply stems from the fewer MART iterations required
for each time instant. Moreover, the method yields superior
reconstruction quality and higher velocity field measurement
precision when compared with both MART and
MTE-MART. The working principle is assessed in terms
of computational effort, reconstruction quality and velocity
field accuracy with both synthetic time-resolved tomographic
images of a turbulent boundary layer and two
experimental databases documented in the literature. The
first is the time-resolved data of flow past an airfoil trailing
edge used in the study of Novara and Scarano (Exp Fluids
52:1027–1041, 2012); the second is a swirling jet in a water
flow. In both cases, the effective elimination of ghost particles
is demonstrated in number and intensity within a short
temporal transient of 5–10 frames, depending on the seeding
density. The increased value of the velocity space–time
correlation coefficient demonstrates the increased velocity
field accuracy of SMTE compared with MART.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
