方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 其他>其他 |
参考标准 | 暂无 |
用LaVision公司以增强型CCD相机为核心部件构成的PLIF激光诱导荧光成像系统定量地测量了柴油发动机中NO自由基的激光诱导荧光成像并进行了数据后处理。
The imaging of in-cylinder NO distributions in a
steadily running optically accessible diesel engine operated
on standard diesel fuel is performed by means of the 2DLIF
technique and a tunable ArF excimer laser at 193 nm.
Simultaneous excitation at 226 nm showed that no sizable
photo-chemical effects are induced by the excimer laser. In
order to account for the gradually decreasing transparency of
the windows due to soot deposits and for the in-cylinder attenuation
of the laser intensity, signal processing procedures for
the imaged distributions are presented. In addition to the more
realistic depictions of NO distributions at selected crank angles
and loads resulting from these procedures, the latter are
an essential step towards a quantitative interpretation of the
corresponding in-cylinder NO concentrations.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
