方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 热性能>燃烧特性 |
参考标准 | 暂无 |
采用由LaVision公司的增强型CCD像机为核心构成的平面激光诱导荧光PLIF测试系统,用激发态复合物Exciplex作为示踪粒子,分析研究汽车发动机燃料混合物的制备过程特别是喷雾气液两相转化过程。
In this work we study mixture preparation inside the cylinder of an optically accessible DI gasoline-engine. Crank
angle resolved investigation of the atomization process of different model-fuels is carried out by means of planar
Mie-scattering. The vaporization of the liquid fuel and the transport processes inside the cylinder are studied by
planar Laser-Induced-Exciplex-Fluorescence (PLIEF) using two different exciplex-systems and two different
model-fuels. Besides the standard mono-component model fuel isooctane a newly developed multi component fuel
(MCF) was examined. It represents the boiling curve of standard gasoline quite well and shows nearly the same
spectroscopic characteristics as isooctane. The crank angle resolved liquid and vapor distributions for a stratified and
a homogeneous operation mode are visualized for both model fuels and both exciplex-tracers. Furthermore cyclic
variations of vaporized fuel distributions near the spark plug are investigated. Simultaneous detection of the incylinder
pressure allowed the correlation between the fuel vapor distribution near the spark plug and the combustion
quality of this air-fuel-mixture. The corrected intensity values of the fluorescence emissions of the two exciplexsystems
TMPD/naphthalene and TEA/benzene were compared under same operation conditions.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
