方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 热性能>燃烧特性 |
参考标准 | 暂无 |
采用LaVision公司由增强型CCD相机构成的平面激光诱导荧光(PLIF)测试系统对直喷汽油发动机内混合物形成的不同的激发态复合物和模型燃料的应用有效性进行了分析研究。
In this work we study mixture preparation inside the cylinder of an optically accessible DI gasoline-engine. Crank angle
resolved investigation of the atomization process of different model-fuels is carried out by means of planar Mie-scattering.
The vaporization of the liquid fuel and the transport processes inside the cylinder are studied by Planar Laser-Induced-
Exciplex-Fluorescence (PLIEF) using two different exciplex-systems and two different model-fuels. Besides the standard
mono-component model fuel isooctane a newly developed multi component fuel (MCF) was examined. It represents the
boiling behaviour of standard gasoline quite well and shows almost the same spectroscopic characteristics as isooctane. The
simultaneously recorded crank angle resolved distributions of liquid and vaporized fuel for a stratified and homogeneous
operation are visualized for both model fuels and both exciplex-tracers. The corrected intensity values of the fluorescence
emissions of the two exciplex-systems TMPD/naphthalene and TEA/benzene were compared under same operation
conditions.
Furthermore cyclic variations of vaporized fuel distributions near the spark plug are investigated. Simultaneous detection of
the in-cylinder pressure allowed the correlation between the fuel vapor distribution near the spark plug and the combustion
quality of this air-fuel-mixture.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
