方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车排放与节能 |
检测项目 | 理化分析>其他 |
参考标准 | 暂无 |
采用LaVision公司的增强型CCD相机对燃烧过程中的重要中间产物甲醛的浓度分布进行了定量测量。采用了LaVision公司独特的激光诱导荧光燃烧火焰分析测试系统Flame-Master
Formaldehyde (CH2O) is an important intermediate species in combustion processes and it can through laserinduced
fluorescence measurements be used for instantaneous flame front detection. The present study has focussed on
the use of the third harmonic of a Nd:YAG laser at 355 nm as excitation wavelength for formaldehyde, and different
dimethyl ether (C2H6O) flames were used as sources of formaldehyde in the experiments. The investigations included
studies of the overlap between the laser profile and the absorption lines of formaldehyde, saturation effects and the
potential occurrence of laser-induced photochemistry. The technique was applied for detection of formaldehyde in an
internal combustion engine operated both as a spark ignition engine and as a homogenous charge compression ignition
engine.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
