方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 理化分析>其他 |
参考标准 | 暂无 |
采用LaVision公司以增强型CCD相机为核心部件构成的平面激光诱导荧光测试系统和喷雾激光成像方法,对火花塞引燃汽油发动机中燃烧室表面燃料薄膜的厚度今行了测量和研究。
Up to 90% of the unburnt hydrocarbon emissions (UHCs) from modern 4-stroke gasoline engines occur during cold
starting. Slow vapourisation particularly from films of fuel in the intake port, and on the manifold and cylinder walls leads
regions of rich mixture and incomplete combustion. To reduce UHCs it is useful to know where, and how thick, these wall
films are during the intake and compression strokes.
In the present work the fuel film is imaged and its depth measured with a laser induced fluorescence technique. The
technique uses a with a pulsed laser, diffuse illumination and a camera and images the film on the metal combustion
chamber surface, in an inexpensive rig closely approximating the flow in an port injected gasoline engine under cold
start. The temporal resolution of ~100ns and spatial resolution of ~0.5mm are sufficient to reveal the detailed dynamics of
the film formation and transport.
The technique functions well in the imperfect optical environment of a piston engine cylinder. In contrast to previous
studies the film depth is measured, quantitatively, on the metal combustion chamber surface with correct roughness and
film transport properties, rather than on a smooth glass wall. The uncertainty in depth is ±16mm but may be reduced to
±5mm. With open valve injection a 30±16mm thick film forms on the exhaust side cylinder wall. Such films lead to high
unburnt hydrocarbon (UHC) emissions. The technique has high temporal (100ns) and spatial (0.5mm) resolution and may
be applied to acceleration transients, lubricating oil films, GDI and Diesel engines.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
