方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 理化分析>加热流动性 |
参考标准 | 暂无 |
才用LaVision公司特色的DaVis软件平台构成的完整粒子成像测速(PIV)系统对直喷柴油发动机中多漩涡流动进行了测量和分析
The amount of soot emissions from small high-speed direct-injection diesel engines is sensitively
dependent on the strength of the in-cylinder swirl flow which is important for the formation of an
ignitable mixture. Three optical techniques - Particle Image Velocimetry (PIV), a full-field
correlation method based on high-speed video recording of the swirling flames, and an optical probe
technique - have been applied to characterise the setup and the final strength of the swirling air
motion during compression stroke and the time of combustion. Two different swirl levels were
investigated. The experimental results are compared to calculations based on integral flow
measurements performed under steady-state conditions. The final swirl at the time of combustion
predicted by the simple model calculation is in good agreement with the experimental results.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
