方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 热性能>其他 |
参考标准 | 暂无 |
采用LaVision公司的平面激光诱导荧光(PLIF)测试系统和以DaVis软件平台为基础构成的粒子成像测速(PIV)系统对直喷火花塞引燃(DISI)发动机工作在分层燃烧模式下燃料充量运动和混合物形成的周期性起伏现象进行了观测和研究。
The processes of an internal combustion engine are subject to cyclic fluctuations, which have direct consequence on the
operational and emission behavior of the engine. Direct injection gasoline engines have fluctuations that are induced and
superimposed by the flow and the injection. In stratified operation they can cause serious operating problems, such as
misfiring. Currently, the state of knowledge on the formation and causes of cyclic fluctuations is rather limited, which can
be attributed to the complex nature of flow instabilities.
Recent analyzes of a direct injection gasoline engine’s cyclic fluctuations of the in-cylinder charge motion and the mixture
formation utilizes laser-optical diagnostics and numerical 3D-calculations. Individual cycles are measured using optical
measurement techniques and pressure indicators for determining flow, mixture formation, and the combustion processes.
Large-scale turbulence and cyclic fluctuations are modeled using 3D-calculations that are performed with a Large Eddy
Simulation (LES). The results of the calculations are used to analyze the formation of cyclic fluctuations and their effect on
injection and mixture formation.
The intensity of the cyclic fluctuations rises dramatically during the injection phase, because of the relationship between
the cyclic fluctuating in-cylinder flow and the injection. These results are confirmed by calculations, which when combined
with reproducible injection predict strongly differing mixture states at the ignition point with significant asymmetries. These
asymmetries with their broad scatter range of mixture formation can explain the stochastic misfires that occur in the
engine.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
