方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
This paper presents quantitative planar laserinduced fluorescence (PLIF) imaging of nitric oxide (NO) in a transient-arc direct-current plasmatron igniter using premixed air/fuel mixtures. Quantitative measurements of NO are reported as a function of gas flow rate (20–50 standard cubic feet per hour), plasma power (100–900 mA, 150–750 W), and equivalence ratio (0.7–1.3). Images were corrected for temperature effects by using 2-D temperature field measurements obtained with infrared thermometry and calibrated by a more accurate multiline fitting technique. The signals were then quantified using an NO addition method and spectroscopic laser-induced fluorescence modeling of NO. NO PLIF images and single-point NO concentrations are presented for both plasma-discharge-only and methane/air plasma-enhanced combustion cases. NO formation occurs predominantly through N2(v) + O → NO + N for the plasmadischarge- only case without combustion. The NO concentration for the plasma-enhanced combustion case (500–3500 ppm) was an order of magnitude less than the plasma-discharge-only case (8000–15 000 ppm) due to the reduction of plasma reactions by the methane. Experiments show the linear decay of NO from equivalence ratio 0.8–1.2 under the same flow condition and discharge current. Index Terms—Nitric oxide (NO), plasma torch, plasma-assisted combustion.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
