方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium公司的无光纤式集成化DPSSL半导体泵浦的固体激光器构成的相位多普勒干涉仪测量系统,测量高速空气流中两个空气雾化喷嘴的喷雾中的液滴粒径和速度,并研究了其相互作用规律。
Air atomizing nozzles are used to produce a polydisperse distribution of droplets. When droplets exiting a nozzle collide with droplets from other sprays, they may either coagulate and grow in size or potentially undergo further atomization and reduce in size. The size and relative motion of the individual droplets will have a significant effect on the process. In addition, when the droplets are subjected to external velocities that result in turbulent flow, shear coagulation can have a substantial impact on the combined spray distribution, especially for larger droplets. For our current study, we are developing an array of air atomizing nozzles to produce airborne icing clouds, with median volume diameters (MVD) in the 20 to 50 m range. The nozzles are spaced approximately 10 centimeters apart hor-izontally and subject to wind speeds ranging from 50 to 140 knots. The shearing effect created by the relative wind speed may reduce the initial droplet size by secondary atomization, while the droplet interactions may lead to coagu-lation. These competing phenomena were evaluated using an Artium Phase Doppler Interferometer (PDI) to charac-terize the size distribution of droplets undergoing simultaneous shear and coagulation. The data show that the air flowing past the nozzles had a significant effect upon the droplet size for individual nozzle sprays, reducing the MVD by 27% on average. The data also showed the combined spray from two nozzles had a 9% larger MVD than that from a single nozzle; however, with the reduction in droplet size due to the high velocity (HV) air flow, the overall MVD was still reduced (24% on average). This paper further describes the test results for one and two noz-zles generating droplets in still air and with HV air flow, and how the droplet size and water flow rate appeared to influence the evaporation /coagulation ratio.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
