方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用德国LaVision公司的高速时间分辨立体激光成像测速系统PIV和相位多普勒干涉仪系统,对曲面内壁喷嘴燃烧器中湍流喷雾火焰流场和液滴动力学进行了测量和研究
A curved wall jet (CWJ) burner was employed to stabilize turbulent spray flames that utilize a Coanda effect; air is
supplied as an annular-inward jet over a curved surface, surrounding an axisymmetric solid cone fuel spray. Flow
velocity fields of the oxidizer and droplet size and velocity data were measured using Stereoscopic Particle Image
Velocimetery (SPIV) and a Phase Doppler Interferometer (PDI) system, respectively. SPIV measurements revealed
that the general features of the flow field exhibit typical flow characteristics of the CWJ burner. As the air flow rate
increases, the droplets size (D32) decreases upstream at off-center positions and becomes more uniform in the radial
direction. Moreover, the mean axial droplets velocity reduces in the near-field flow of flames.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
