方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium公司的相位多普勒粒子干涉仪(PDI)和德国LaVision公司的喷雾测试系统SprayMaster对多注入角度喷雾进行了实验和计算模拟研究。
The interaction of a spray plume within a confined cross-flow environment represents a common spray application
environment, most notably in gas conditioning applications. Characterization and modeling of the downstream drop
size and velocity distributions, as well as spray coverage & shape, was conducted within a controlled wind tunnel
environment. The primary focus of this study is the effect of various incident angle cross-flows on the characteristics
of a spray distribution.
While the spray characteristics immediately downstream of the nozzle will govern the magnitude of the effect of the
cross-flow, this study aims to provide a reference case in order to guide and compare future work. A low flow rate,
hydraulic, hollow cone spray was investigated with a nominally uniform cross-flow air speed of 15 m/s. These results
demonstrate the trajectory change as well as the change in spray plume characteristics over a range of spray
angles defined relative to the co-flow air stream direction.
The experimental results were acquired with a LaVision Laser Sheet Imaging (LSI) and an Artium Phase Doppler
Interferometer (PDI), to measure the spray shape, size, distribution characteristics as well as droplet size and velocity.
The spray simulations were conducted using ANSYS FLUENT computational fluid dynamics (CFD) package in
conjunction with custom spray injection methods developed in-house. The computational model’s agreement, and
disagreement, with the experimentally acquired results provides insight for the appropriate considerations when constructing
cross-flow models.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
