方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium公司的无需光纤的半导体泵浦的固体激光器(DPSSL)集成在发射头内的激光相位多普勒粒子干涉仪,对高雷诺数湍流中的惯性粒子团聚线性进行了实验研究和分析。
We report experimental evidence of spatial clustering of dense particles in homogenous, isotropic
turbulence at high Reynolds numbers. The dissipation-scale clustering becomes stronger as the Stokes
number increases and is found to exhibit similarity with respect to the droplet Stokes number over a range
of experimental conditions (particle diameter and turbulent energy dissipation rate). These findings are in
qualitative agreement with recent theoretical and computational studies of inertial particle clustering in
turbulence. Because of the large Reynolds numbers a broad scaling range of particle clustering due to
turbulent mixing is present, and the inertial clustering can clearly be distinguished from that due to mixing
of fluid particles.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
