方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium公司无需光纤的集成了半导体泵浦固体激光器(DPSSL)的激光相位多普勒粒子干涉仪(PDI-100MD)对喷雾对象中的喷雾液滴粒子粒径和速度进行了实时测量和记录。这是一种表征喷雾特性的有效方法。
Refineries and chemical plants employ sprays in columns that often exceed 20 feet in diameter. Sprays are used to transfer heat, to feed beds of packing and to feed simple contacting trays. Very large nozzles are employed. Multi-nozzle sprays are employed. Very little is known about the actual performance of these spray nozzles in these hy-drocarbon and dirty hydrocarbon services. Several oil and chemical companies have convinced Fractionation Re-search Inc. (FRI) to review its 50-year history of spray nozzle research and to perform new research with water and also with hydrocarbons in its 4-foot diameter windowed test columns. The FRI apparatuses are on the Oklahoma State University (OSU) campus. For the last two years, OSU has been studying carbon dioxide removal from flue gases using spray columns. Carbon dioxide is a greenhouse gas, and many people believe that this gas is causing climate change. Together, the FRI and OSU engineering staffs have embarked on a large spray nozzle test program. A patternator is being employed along with an Artium Technologies Phase Doppler Interferometer (PDI). This presentation will include film/video footage of spray nozzles functioning with hydrocarbon liquids - and vapors.
*Corresponding
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
