方案下载应用领域 | 航空航天 |
检测样本 | 航空 |
检测项目 | |
参考标准 | 暂无 |
采用LaVison公司的智能成像测量系统中的平面激光诱导荧光测量方法,用丙酮做示踪剂,研究了超音速气体引射器中的混合过程。
Supersonic mixing studies are important in the design and development of efficient supersonic
ejectors. As a gas-dynamic device, supersonic ejector pumps up the secondary flow using the
higher kinetic energy of the primary flow itself. Conventional techniques have limited access to
acquire data in such kind of flows to calculate the mixing efficiency. Reacting flows poses further
challenge in instrumentation. Experiments in cold flows manage to reveal important aspects on
supersonic mixing. Advanced optical flow diagnosis helps in probing the flow without large intrusion.
One of such non-intrusive flow diagnostics is Acetone PLIF. A low area ratio supersonic
ejector, operating at a MPD of 2.0 for the range of POP from 4.89 bar to 8.89 bar is taken into
consideration for this experiment. Secondary air intake duct is kept open during this operation and
the ejector is operated in the mixed flow regime. Concentration distribution is qualitatively evaluated
in this experimentation and few basic flow features are captured. Diffusion of secondary flow
into the primary flow and thickening mixing layers are clearly captured. NML computed from
PLMS experiments are also cross verified with current experiments as the mixing process is found
to be happening well above the NML as expected.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
