方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的ImagerIntense型CCD相机和NewWavePIV激光器对甲烷加氧气和氢气加氧气两种燃料混合物火焰流场进行了测量,并研究观察了高压高频放电对流场形态,燃烧形态的影响,分析了影响机理,并探讨了可能的应用。
This study investigates the changes induced by plasma-excited oxygen, in the flow field of partially-premixed CH4
and H2 flames under atmospheric conditions. Excited singlet oxygen is known to promote the chain mechanism
reactions that control ignition and burning. Resulting modifications of the flame structure have been analyzed in
previous works [1, 2] by different spectroscopic methods. The results of these measurements showed that the flow
attaches closer to the burner surface and that the reaction zone becomes more concentrated toward the center of the
system, when activating the plasma discharge. All these observations indicate strong changes in flow and flame
topology induced by the plasma discharge. Therefore, additional velocity measurements have been carried out in this
work, in order to verify these qualitative observations. The results of these measurements support the earlier
presumption: when the plasma is on, the flow fields become more turbulent, higher velocities are observed and the
flow turns preferentially toward the center of the burner.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
