方案下载应用领域 | 地矿 |
检测样本 | 非金属矿产 |
检测项目 | |
参考标准 | 暂无 |
采用立陶宛Ekspla公司的振动和频光谱测量系统(VS-SFG),激光器脉冲宽度20皮秒。对锂辉石表面进行了测量研究。研究了其润湿特性和收集吸附过程之间的关联。
The selective flotation separation of spodumene from other aluminosilicate minerals remains a challenging problem in flotation chemistry, and the surface chemistry features are of fundamental importance. In this study,the interfacial chemistry features, particularly the wetting characteristics of selected spodumene surfaces (1 1 0,0 0 1, 0 1 0, and 1 0 0 crystal surfaces), in the absence and presence of collectors, were studied by water contact angle and bubble attachment measurements, molecular dynamics (MD) simulation, and sum-frequency vibrational spectroscopy (SFVS). The experimental results revealed the interfacial water structure at spodumene surfaces. Contact angle, bubble attachment measurements, and MD simulation results showed that the four spodumene surfaces were naturally hydrophilic, whereas in the presence of collectors, preferential adsorption of sodium oleate on the (1 0 0) and (1 1 0) surfaces was found to create a hydrophobic surface state. Detailed
analysis of the interfacial water structure was conducted in order to understand the wetting characteristics at the molecular level, and SFVS was used to study the state of collectors at selected surfaces. The MD simulation and SFVS results revealed that the natural state of the surfaces contributes to the distinct interfacial water structure and the adsorption state of collectors. It seems that unsaturated Al sites at the spodumene surface and their spatial locations account for chemisorption of sodium oleate, while electrostatic attraction appears to be the main driving force for dodecylamine adsorption.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
