方案下载应用领域 | 石油/化工 |
检测样本 | 苯及其衍生物 |
检测项目 | 可靠性能 |
参考标准 | 暂无 |
采用立陶宛Ekspla公司PL2250型皮秒脉冲Nd:YAG激光器输出的532nm和 1064nm波长,30ps脉宽,10Hz重复频率的激光脉冲,激发石墨混合物中的固体三硝基甲苯观测其拉曼和时间分辨脉冲光声光谱用于识别双共振光学声子信号。
The optical phonon waves transfer mechanism between pure graphite (GP) and trinitrotoluene (TNT) using 1064 nm as an excitation wavelength based on the double resonant Raman effect and the pulsed photoacoustic (PA) technique has been investigated. The study was carried out at a different weight percentage of GP within TNT with respect to the two excitation wavelengths of 532 nm and 1064 nm (30 ps, 10 Hz, Q-switched Nd: YAG
laser). The equal and double proportional matrix of the GP and TNT (solid samples) generate a strong PA signal with high quality factor (Q-factor) due to the interaction of optical phonons of GP and TNT in the same phase. The Raman spectra, recorded at 785 nm wavelength provides an insight on the pi-electron coupling between the GP and TNT. The obtained experimental results confirm that the pure GP and its derivatives, which have a SP2/
SP3 hybridization, can be used to develop a new sensing optode for the detection and identification of explosive molecules in the visible and near-IR wavelengths range.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
