方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | 理化分析 |
参考标准 | 暂无 |
采用立陶宛EKSPLA公司研制的NL301HT型纳秒调Q Nd:YAG激光器输出的355nm激光进行选择性紫外光致解离,配合质谱仪,进行了气相交联测量,和波恩-奥本海默分子动力学计算。探测了非共价肽肽离子复合物中精氨酸-磷酸肽相互作用
We report a study of non-covalent complexes of phosphopeptides pXAAAA and N-Ac-pXAAAA (X = Ser,Thr, Tyr) with arginine-containing peptides carrying diazirine 4,4-azipentyl tags at the N-terminus,*LGG(A)nR, or in the photoleucine residue, L*GG(A)nR (n = 3–5). Complexes with *LGG(A)nR were successfully generated as singly charged ions in the gas phase in 0.6–3.5% yields. In contrast, complexes with L*GG(A)nR were formed in negligible (<0.1%) yields. Selective photodissociation at 355 nm of the diazirine ring in [*LGG(A)nR + pXAAAA + H]+ ions resulted in loss of N2, producing large (75–95%) fractions
of non-dissociating complexes that were further probed by collision-induced dissociation tandem mass spectrometry (CID-MS3). Covalent cross-links in the complexes produced by photoinduced carbene insertion were identified by specific CID-MS3 dissociations involving H3PO4 transfer and backbone fragmentations. N-acetylation in the phosphopeptides was found to have a substantial negative effect on the formation of covalent cross-links. Amongst the phosphorylated amino acid residues, pTyr showed the highest tendency (up to 92%) to form covalent cross-links. The fractions of covalent cross-links substantially increased with the length of the photopeptide chain. Born-Oppenheimer molecular dynamics (BOMD) calculations of canonical and zwitterionic protomers of the (pYAAAA + *LGGAAAR + H)+ complex indicated multiple close contacts between the incipient carbene of the diazirine ring and the X H bonds (X C, N, O) in the phosphopeptide. BOMD in combination with structural analysis by density functional theory calculations were used to interpret the experimental data and explain the cross-linking efficiencies.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
