方案下载应用领域 | 航空航天 |
检测样本 | 航天 |
检测项目 | |
参考标准 | 暂无 |
采用Ekspla公司的NL300HT激光器泵浦光学参量发生器,产生高能量可调谐纳秒激光输出。在AEgIS实验中,用于激发Na22同位素,产生正电子偶素。
The AEgIS experimental program on antimatter systems involves the formation of antihydrogen atoms for gravitational and CPT studies. One of the key ingredients of the
AEgIS strategy for the synthesis of antihydrogen atoms is the creation and manipulation
of Positronium (Ps) atoms laser excited to Rydberg states (n > 15).
In AEgIS, Ps is produced in bunched mode and the Rydberg excitation is achieved with
a two laser pulse technique, by passing through a n = 3 intermediate level. Because excitation on Ps n = 3 state has never been proposed before, in AEgIS a dedicated experimental apparatus and several detection strategies have been studied in order to observe the first measurement ever on this interesting process. In this work we present and discuss the experimental findings about the successful Ps n = 3 excitation.
Moreover, in this thesis, a study of the impact of involved nonlinear processes on the
excitation efficiency of a Doppler broadened atomic cloud is carried out. Presented simulation
results show that, by exploiting properly nonlinear processes in the generation of the desired wavelength, it is possible to improve the excitation efficiency of a laser pulse. It is crucial, in AEgIS, the use of a periodically poled crystal in quasi phase matching regime. This gives a broadband continuous output spectrum whose wings survive to the spectral cutting of the last nonlinear crystal of the chain (which has insufficient spectral acceptance). This means that, at high laser energies, these wings can be amplified and the spectrum gaps can be filled in, leading to high reachable saturation efficiencies. On the contrary, in a laser pulse with a comb-shaped spectrum with a Gaussian envelope, both wings and gaps drop rapidly to zero, and amplification hardly occurs at usually employed energy regimes.
The presented model is finally used to fit AEgIS Ps n = 3 excitation experimental data.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
